[GRASSGUI] Re: wx start error
Michael Barton michael.barton at asu.edu
Tue Aug 7 16:35:34 EDT 2007
William,
Thanks for troubleshooting.
On 8/7/07 1:17 PM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> It's in the Spearfish mapset.  g.region -gp works without problems.
> The gis_set.py problem at least I can understand - the line:
> key,val = line.split(":")
> doesn't seem to work when there is more than one delimiter in the
> string.  Setting DEBUG=GUI:3 creates this in grassrc6:
> DEBUG: GUI:3
There needs to be a better way to set this that won't kill gis_set.py. I
think Martin worked out the debug routine.
Martin: any other way to specify debug? Maybe some way to specify the 1st
colon in the split. Have to look it up.
> For the bigger problem, after poking around,
> [snipped what I was going to say before I updated from CVS]
> It appears I have no "module-d.shadedmap.gif" in my gui icon set
> (grass src/gui/icons).  And, I just updated from CVS and there it is!
I wish there was a way to trap a missing icon error. It it not easy to spot.
Michael
> On Aug 7, 2007, at 2:26 PM, Michael Barton wrote:
>> William,
>> This kind of looks like a problem specific to your system.
>> Something is
>> wrong in your GRASS settings file. Maybe an invalid gis database,
>> location,
>> or mapset. This is causing the startup to fail and default into the
>> text
>> interface. Try running g.region -gp. I suspect it will give
>> problematic
>> results.
>> Michael
>> On 8/7/07 9:31 AM, "William Kyngesburye" <woklist at kyngchaos.com>
>> wrote:
>>> An error trying to start wxgrass.  With 'wxgrass&' from a running
>>> GRASS session, I get this error.  Interestingly, if I set
>>> my .grassrc6 to wx, I get the same error after a gis_set.py error,
>>> but GRASS automatically starts in the last mapset I was in (as is set
>>> in .grassrc6), instead of bailing completely (since gis_set.py
>>> failed).
>>> The gis_set.py error appears only if I have DEBUG set to GUI:3 (it
>>> doesn't like the : there).  I get the normal mapset selection in
>>> python if DEBUG is not set or is set to just a number.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
More information about the grass-gui mailing list
