[GRASS-GUI] Hoping for some assistance
Martin Landa landa.martin at gmail.com
Tue Apr 9 00:40:10 PDT 2013
2013/4/9 Michael Mavis <mjmvs at yahoo.com>:
> Whenever I display the Attribute Table Manager, in virtually every
> circumstance I have tried, both the Manage Tables and Manage Layers tabs
> display their respective pages, but the pages are entirely disabled. Not
> once have they been enabled.
you can edit attribute data linked with vector maps only from your
current mapset [1].
> Also, with the Browse Data tab, I can run a query, but in no circumstance
> that I can recall have I been able to edit a record; the edit option has
> been disabled.
See above.
> My first question is: When are these options enabled?
Only for vector maps from your current mapset.
> A related question might be: Is a 64-bit operating system a problem, and
> should I change to something different? If need be I could switch to a
> Windows 7: 32-bit system.
Not related, at this moment we have only 32-bit winGRASS, 64-bit
version is under development [2].
Martin
[1] http://grasswiki.osgeo.org/wiki/Location_and_Mapsets
[2] http://trac.osgeo.org/grass/wiki/CompileOnWindows
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
More information about the grass-gui mailing list
