[GRASS-PSC] How to modify module folder content in SVN
Eva Stopková eva.stopkova at gmail.com
Tue Jun 23 10:07:50 PDT 2015
Dear Vašek and Moritz,
thank you for suggestions.
I didn't get that before, but I agree with Moritz that two versions are not
> ideal. Is there any reason to keep both? Performance? Different quality
> algorithms/results? Do you have some tests or benchmarks which would
> compare them?
I have done some tests, v.nnstat gives identical results in both versions.
While testing the module using dataset of approx. 300 000 points, the
version with R-tree used to crash, but now it seems to work correctly, so
there is no need to maintain also PCL version.
In v.kriging, there are some differences in results - I supposed that they
are caused by different approach of kd- / R- tree, but I have just found a
bug in my code... so I agree it will not be necessary to maintain both C
and C++ versions, but still I would like to wait with the announcement
until I fix that bug.
Best regards,
Eva
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20150623/eb46c53c/attachment.html>
More information about the grass-psc mailing list
