[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/make_loc.c |no clones | 0 monsters | 0 warnings
Tue Dec 12 04:19:14 EST 2006
Hello paul,
ANALYSIS
lib/gis/make_loc.c functions
G__make_location (Begins at: 42 Ends at: 124)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
G_make_location (Begins at: 126 Ends at: 168)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
G_compare_projections (Begins at: 171 Ends at: 245)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
