[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/unix_socks.c |no clones | 0 monsters | 0 warnings
Thu Dec 14 12:40:27 EST 2006
Hello markus,
ANALYSIS
lib/gis/unix_socks.c functions
_get_make_sock_path (Begins at: 61 Ends at: 107)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
G_sock_get_fname (Begins at: 116 Ends at: 135)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
G_sock_exists (Begins at: 144 Ends at: 163)
CalledNBR:    |       2 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
G_sock_bind (Begins at: 166 Ends at: 205)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
G_sock_listen (Begins at: 214 Ends at: 226)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
G_sock_accept (Begins at: 229 Ends at: 243)
LOC:          |      15 |       |      OK |
metrics are OK
G_sock_connect (Begins at: 246 Ends at: 271)
Complexity:   |       4 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
G_sock_socketpair (Begins at: 276 Ends at: 284)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
