[GRASS-QA] GRASS QA: markus | ./grass6/display/d.rast.edit/main.c |1 clones ( edit.c main.c )| 0 monsters | 0 warnings
Fri Dec 15 05:35:15 EST 2006
Hello markus,
ANALYSIS
display/d.rast.edit/main.c functions
main (Begins at: 28 Ends at: 115)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      88 |       |      OK |
metrics are OK
do_edit (Begins at: 118 Ends at: 154)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
error (Begins at: 156 Ends at: 183)
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
ext (Begins at: 187 Ends at: 194)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  ext
In display/d.rast.edit/main.c clones of  ext are:
	vector/lidar/v.lidar.growing/ConvexHull.c  nrerror
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
