[GRASS-QA] GRASS QA: markus | ./grass6/ps/ps.map/r_cell.c |no clones | 0 monsters | 0 warnings
Fri Dec 15 05:48:12 EST 2006
Hello markus,
ANALYSIS
ps/ps.map/r_cell.c functions
read_cell (Begins at: 11 Ends at: 49)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-15 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
