[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/window_map.c |no clones | 0 monsters | 0 warnings
Mon Dec 18 03:26:05 EST 2006
Hello brad,
ANALYSIS
lib/gis/window_map.c functions
G__create_window_mapping (Begins at: 31 Ends at: 128)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      98 |       |      OK |
metrics are OK
G_northing_to_row (Begins at: 130 Ends at: 147)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
G_adjust_east_longitude (Begins at: 149 Ends at: 172)
Complexity:   |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_adjust_easting (Begins at: 174 Ends at: 184)
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
G_easting_to_col (Begins at: 186 Ends at: 216)
LOC:          |      31 |       |      OK |
metrics are OK
G_row_to_northing (Begins at: 218 Ends at: 238)
LOC:          |      21 |       |      OK |
metrics are OK
G_col_to_easting (Begins at: 240 Ends at: 253)
LOC:          |      14 |       |      OK |
metrics are OK
G_window_rows (Begins at: 255 Ends at: 287)
ParamNBR:     |       0 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G_window_cols (Begins at: 289 Ends at: 294)
LOC:          |       6 |       |      OK |
metrics are OK
G__init_window (Begins at: 296 Ends at: 312)
Complexity:   |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_row_repeat_nomask (Begins at: 314 Ends at: 343)
Complexity:   |       5 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
