[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.setproj/proj.c |no clones | 0 monsters | 0 warnings
Mon Dec 18 13:40:48 EST 2006
Hello glynn,
ANALYSIS
general/g.setproj/proj.c functions
get_proj_unit (Begins at: 9 Ends at: 46)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
get_proj_desc (Begins at: 48 Ends at: 84)
CalledNBR:    |      12 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
get_proj_parms (Begins at: 86 Ends at: 184)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-18 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
