[GRASS-QA] GRASS QA: brad | ./grass6/lib/segment/format.c |no clones | 0 monsters | 1 warnings
Wed Dec 27 02:39:56 EST 2006
Hello brad,
ANALYSIS
lib/segment/format.c functions
segment_format (Begins at: 41 Ends at: 44)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
segment_format_nofill (Begins at: 46 Ends at: 50)
LOC:          |       5 |       |      OK |
metrics are OK
_segment_format (Begins at: 52 Ends at: 101)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      11 |       |      OK |
LOC:          |      50 |       |      OK |
at least 1 values are close to an outlier please consider revising code
write_int (Begins at: 103 Ends at: 113)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
zero_fill (Begins at: 115 Ends at: 160)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-27 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
