[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.out.dxf/main.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Jul 13 15:33:58 EDT 2006
Hello cho,
ANALYSIS
vector/v.out.dxf/main.c functions
main (Begins at: 39 Ends at: 92)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
do_limits (Begins at: 94 Ends at: 111)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
make_layername (Begins at: 114 Ends at: 134)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
add_plines (Begins at: 136 Ends at: 195)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
