[GRASS-QA] GRASS QA: cho | ./grass6/vector/v.out.dxf/write_dxf.c |no clones | 0 monsters | 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu Jul 13 15:33:58 EDT 2006
Hello cho,
ANALYSIS
vector/v.out.dxf/write_dxf.c functions
dxf_open (Begins at: 15 Ends at: 21)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
dxf_header (Begins at: 23 Ends at: 28)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
dxf_tables (Begins at: 30 Ends at: 35)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_blocks (Begins at: 37 Ends at: 42)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_entities (Begins at: 44 Ends at: 49)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_endsec (Begins at: 51 Ends at: 56)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_eof (Begins at: 58 Ends at: 64)
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
dxf_limits (Begins at: 68 Ends at: 74)
ParamNBR:     |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
dxf_linetype_table (Begins at: 78 Ends at: 83)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_layer_table (Begins at: 85 Ends at: 90)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_endtable (Begins at: 92 Ends at: 97)
LOC:          |       6 |       |      OK |
metrics are OK
dxf_solidline (Begins at: 99 Ends at: 106)
LOC:          |       8 |       |      OK |
metrics are OK
dxf_layer0 (Begins at: 108 Ends at: 114)
LOC:          |       7 |       |      OK |
metrics are OK
dxf_layer (Begins at: 116 Ends at: 128)
LOC:          |      13 |       |      OK |
metrics are OK
dxf_point (Begins at: 132 Ends at: 139)
LOC:          |       8 |       |      OK |
metrics are OK
dxf_polyline (Begins at: 141 Ends at: 149)
LOC:          |       9 |       |      OK |
metrics are OK
dxf_vertex (Begins at: 151 Ends at: 158)
LOC:          |       8 |       |      OK |
metrics are OK
dxf_text (Begins at: 160 Ends at: 169)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      10 |       |      OK |
at least 1 values are close to an outlier please consider revising code
dxf_poly_end (Begins at: 171 Ends at: 176)
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-07-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      80 |
LOC:                    40 |       180 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
