[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:46 EDT 2006
Hello brad,
ANALYSIS
lib/image/open.c functions
iopen (Begins at: 41 Ends at: 45)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
at least 1 values are close to an outlier please consider revising code
fiopen (Begins at: 47 Ends at: 51)
LOC:          |       5 |       |      OK |
imgopen (Begins at: 53 Ends at: 201)
Complexity:   |      26 |    ** | Warning |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      41 |     * |         |
LOC:          |     149 |     * |         |
1 metric are OUT OF RANGE!
ibufalloc (Begins at: 203 Ends at: 206)
ParamNBR:     |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
reverse (Begins at: 208 Ends at: 214)
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
cvtshorts (Begins at: 216 Ends at: 226)
LOC:          |      11 |       |      OK |
metrics are OK
cvtlongs (Begins at: 228 Ends at: 241)
LOC:          |      14 |       |      OK |
metrics are OK
cvtimage (Begins at: 243 Ends at: 248)
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
i_errhdlr (Begins at: 259 Ends at: 272)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
i_seterror (Begins at: 275 Ends at: 278)
LOC:          |       4 |       |      OK |
metrics are OK
getshort (Begins at: 282 Ends at: 287)
LOC:          |       6 |       |      OK |
metrics are OK
getlong (Begins at: 290 Ends at: 296)
LOC:          |       7 |       |      OK |
metrics are OK
putshort (Begins at: 299 Ends at: 305)
LOC:          |       7 |       |      OK |
metrics are OK
putlong (Begins at: 308 Ends at: 316)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
