[GRASS-QA] SOCCER LAB GRASS QA: 8 clones ( Dscreen.c list.c get_row.c get_row.c put_row.c put_row.c ) 0 monsters and 6 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Jun 13 05:58:45 EDT 2006
Hello brad,
ANALYSIS
lib/gis/put_row.c functions
G_zeros_r_nulls (Begins at: 160 Ends at: 166)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
G_put_map_row_random (Begins at: 168 Ends at: 189)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G__put_null_value_row (Begins at: 191 Ends at: 204)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
G_put_map_row (Begins at: 206 Ends at: 218)
CalledNBR:    |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
G_put_raster_row (Begins at: 220 Ends at: 223)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_put_c_raster_row (Begins at: 225 Ends at: 228)
LOC:          |       4 |       |      OK |
metrics are OK
G_put_f_raster_row (Begins at: 230 Ends at: 233)
LOC:          |       4 |       |      OK |
metrics are OK
G_put_d_raster_row (Begins at: 235 Ends at: 238)
LOC:          |       4 |       |      OK |
metrics are OK
check_open (Begins at: 242 Ends at: 279)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
adjust (Begins at: 281 Ends at: 299)
Complexity:   |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
write_error (Begins at: 301 Ends at: 313)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
G__write_data (Begins at: 317 Ends at: 330)
LOC:          |      14 |       |      OK |
metrics are OK
G__write_data_compressed (Begins at: 332 Ends at: 344)
LOC:          |      13 |       |      OK |
metrics are OK
seek_random (Begins at: 348 Ends at: 360)
LOC:          |      13 |       |      OK |
metrics are OK
set_file_pointer (Begins at: 364 Ends at: 369)
LOC:          |       6 |       |      OK |
metrics are OK
convert_float (Begins at: 375 Ends at: 402)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |      28 |       |      OK |
at least 1 values are close to an outlier please consider revising code
convert_double (Begins at: 404 Ends at: 431)
LOC:          |      28 |       |      OK |
put_fp_data (Begins at: 437 Ends at: 485)
Complexity:   |      14 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      49 |       |      OK |
convert_int (Begins at: 491 Ends at: 537)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      47 |       |      OK |
count_bytes (Begins at: 539 Ends at: 549)
LOC:          |      11 |       |      OK |
metrics are OK
trim_bytes (Begins at: 551 Ends at: 563)
ParamNBR:     |       4 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
same (Begins at: 565 Ends at: 568)
LOC:          |       4 |       |      OK |
metrics are OK
count_run (Begins at: 570 Ends at: 584)
LOC:          |      15 |       |      OK |
metrics are OK
rle_compress (Begins at: 586 Ends at: 610)
LOC:          |      25 |       |      OK |
metrics are OK
zlib_compress (Begins at: 612 Ends at: 619)
LOC:          |       8 |       |      OK |
metrics are OK
put_data (Begins at: 623 Ends at: 702)
CalledNBR:    |      13 |       |      OK |
LOC:          |      80 |       |      OK |
put_raster_data (Begins at: 708 Ends at: 713)
LOC:          |       6 |       |      OK |
put_null_data (Begins at: 719 Ends at: 760)
Complexity:   |       7 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
G__open_null_write (Begins at: 762 Ends at: 778)
LOC:          |      17 |       |      OK |
metrics are OK
G__write_null_bits (Begins at: 780 Ends at: 801)
CalledNBR:    |       7 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
convert_and_write_if (Begins at: 807 Ends at: 820)
LOC:          |      14 |       |      OK |
metrics are OK
convert_and_write_df (Begins at: 822 Ends at: 835)
LOC:          |      14 |       |      OK |
metrics are OK
convert_and_write_id (Begins at: 837 Ends at: 850)
LOC:          |      14 |       |      OK |
metrics are OK
convert_and_write_fd (Begins at: 852 Ends at: 865)
LOC:          |      14 |       |      OK |
metrics are OK
convert_and_write_fi (Begins at: 867 Ends at: 880)
LOC:          |      14 |       |      OK |
metrics are OK
convert_and_write_di (Begins at: 882 Ends at: 895)
LOC:          |      14 |       |      OK |
metrics are OK
put_raster_row (Begins at: 899 Ends at: 938)
Complexity:   |       8 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
Clone analysis:
This file has 8 potentially cloned functions:
  convert_and_write_di  convert_and_write_fi  convert_and_write_fd  convert_and_write_id  convert_and_write_df  convert_and_write_if  convert_double  convert_float
In lib/gis/put_row.c clones of  convert_float are:
	lib/gis/put_row.c  convert_double
In lib/gis/put_row.c clones of  convert_and_write_if are:
	lib/gis/put_row.c  convert_and_write_di
	lib/gis/put_row.c  convert_and_write_fi
	lib/gis/put_row.c  convert_and_write_fd
	lib/gis/put_row.c  convert_and_write_id
	lib/gis/put_row.c  convert_and_write_df
In lib/gis/put_row.c clones of  convert_and_write_df are:
	lib/gis/put_row.c  convert_and_write_if
In lib/gis/put_row.c clones of  convert_and_write_fd are:
In lib/gis/put_row.c clones of  convert_double are:
	lib/gis/put_row.c  convert_float
In lib/gis/put_row.c clones of  convert_and_write_id are:
In lib/gis/put_row.c clones of  convert_and_write_di are:
In lib/gis/put_row.c clones of  convert_and_write_fi are:
Threshold GRASS6 key metrics values at 2006-06-13 are:
                           | quartile  | limit   |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       180 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
