[GRASS-QA] SOCCER LAB GRASS QA: no clones 1 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri May 5 19:38:31 EDT 2006
Hello brad,
ANALYSIS
lib/image/open.c functions
iopen (Begins at: 37 Ends at: 41)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
at least 1 values are close to an outlier please consider revising code
fiopen (Begins at: 43 Ends at: 47)
LOC:          |       5 |       |      OK |
imgopen (Begins at: 49 Ends at: 196)
Complexity:   |      26 |    ** | Warning |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      41 |     * |         |
LOC:          |     148 |     * |         |
1 metric are OUT OF RANGE!
ibufalloc (Begins at: 198 Ends at: 201)
ParamNBR:     |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
reverse (Begins at: 203 Ends at: 209)
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
cvtshorts (Begins at: 211 Ends at: 221)
LOC:          |      11 |       |      OK |
metrics are OK
cvtlongs (Begins at: 223 Ends at: 236)
LOC:          |      14 |       |      OK |
metrics are OK
cvtimage (Begins at: 238 Ends at: 243)
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
i_errhdlr (Begins at: 254 Ends at: 267)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
i_seterror (Begins at: 270 Ends at: 273)
LOC:          |       4 |       |      OK |
metrics are OK
getshort (Begins at: 277 Ends at: 282)
LOC:          |       6 |       |      OK |
metrics are OK
getlong (Begins at: 285 Ends at: 291)
LOC:          |       7 |       |      OK |
metrics are OK
putshort (Begins at: 294 Ends at: 300)
LOC:          |       7 |       |      OK |
metrics are OK
putlong (Begins at: 303 Ends at: 311)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
