[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri May 5 19:38:31 EDT 2006
Hello brad,
ANALYSIS
lib/image/rdwr.c functions
img_seek (Begins at: 15 Ends at: 54)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
img_badrow (Begins at: 56 Ends at: 62)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
img_write (Begins at: 64 Ends at: 74)
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
img_read (Begins at: 76 Ends at: 86)
LOC:          |      11 |       |      OK |
metrics are OK
img_optseek (Begins at: 88 Ends at: 95)
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
