[GRASS-QA] SOCCER LAB GRASS QA: no clones 0 monsters and 2 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri May 5 19:38:31 EDT 2006
Hello brad,
ANALYSIS
lib/image/rle.c functions
img_getrowsize (Begins at: 12 Ends at: 24)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
img_setrowsize (Begins at: 26 Ends at: 78)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
img_rle_compact (Begins at: 80 Ends at: 144)
Complexity:   |      29 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
LOC:          |      65 |       |      OK |
at least 1 values are close to an outlier please consider revising code
img_rle_expand (Begins at: 146 Ends at: 175)
Complexity:   |      25 |     * |         |
LOC:          |      30 |       |      OK |
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
