[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Thu May 18 09:24:15 EDT 2006
Hello radim,
ANALYSIS
vector/v.buffer/main.c functions
input_distance (Begins at: 35 Ends at: 121)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
area_in_buffer (Begins at: 128 Ends at: 207)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      80 |       |      OK |
at least 1 values are close to an outlier please consider revising code
stop (Begins at: 209 Ends at: 217)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
main (Begins at: 220 Ends at: 702)
Complexity:   |      55 |   *** | MONSTER |
CalledNBR:    |     177 |   *** | MONSTER |
LOC:          |     483 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-05-18 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
