[GRASS-QA] SOCCER LAB GRASS QA: 1 clones ( togl_cb.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri May 19 06:16:21 EDT 2006
Hello glynn,
ANALYSIS
visualization/nviz/src/togl_cb.c functions
create_cb (Begins at: 20 Ends at: 25)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
reshape_cb (Begins at: 33 Ends at: 59)
CalledNBR:    |       7 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
display_cb (Begins at: 62 Ends at: 74)
CalledNBR:    |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
swap_togl (Begins at: 76 Ends at: 86)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
load_font (Begins at: 88 Ends at: 107)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
unload_font (Begins at: 109 Ends at: 124)
ParamNBR:     |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
hide_togl_win (Begins at: 126 Ends at: 131)
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
show_togl_win (Begins at: 133 Ends at: 147)
CalledNBR:    |       9 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  unload_font
In visualization/nviz/src/togl_cb.c clones of  unload_font are:
	visualization/nviz/src/change_view.c  Nchange_twist_cmd
Threshold GRASS6 key metrics values at 2006-05-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    40 |       182 |     253 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
