[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/clear_scrn.c |no clones | 0 monsters | 0 warnings
Fri Nov 3 15:24:57 EST 2006
Hello paul,
ANALYSIS
lib/gis/clear_scrn.c functions
G_clear_screen (Begins at: 11 Ends at: 20)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
