[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/datum.c |1 clones ( datum.c )| 0 monsters | 0 warnings
Fri Nov 3 15:24:57 EST 2006
Hello paul,
ANALYSIS
lib/gis/datum.c functions
G_get_datum_by_name (Begins at: 46 Ends at: 57)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
G_datum_name (Begins at: 60 Ends at: 68)
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G_datum_description (Begins at: 71 Ends at: 79)
LOC:          |       9 |       |      OK |
metrics are OK
G_datum_ellipsoid (Begins at: 82 Ends at: 111)
LOC:          |      30 |       |      OK |
metrics are OK
G_get_datumparams_from_projinfo (Begins at: 113 Ends at: 152)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
read_datum_table (Begins at: 155 Ends at: 208)
CalledNBR:    |      15 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
compare_table_names (Begins at: 211 Ends at: 217)
Complexity:   |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  compare_table_names
In lib/gis/datum.c clones of  compare_table_names are:
	raster/r.colors/main.c  cmp_names
Threshold GRASS6 key metrics values at 2006-11-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
