[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/env.c |1 clones ( datum.c env.c )| 0 monsters | 0 warnings
Fri Nov 3 15:24:57 EST 2006
Hello paul,
ANALYSIS
lib/gis/env.c functions
G_set_gisrc_mode (Begins at: 85 Ends at: 88)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_get_gisrc_mode (Begins at: 91 Ends at: 94)
LOC:          |       4 |       |      OK |
metrics are OK
read_env (Begins at: 97 Ends at: 132)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
set_env (Begins at: 134 Ends at: 191)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
unset_env (Begins at: 193 Ends at: 206)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
get_env (Begins at: 208 Ends at: 218)
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
write_env (Begins at: 220 Ends at: 256)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
open_env (Begins at: 258 Ends at: 281)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_getenv (Begins at: 283 Ends at: 292)
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
G_getenv2 (Begins at: 295 Ends at: 304)
LOC:          |      10 |       |      OK |
metrics are OK
G__getenv (Begins at: 306 Ends at: 314)
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G__getenv2 (Begins at: 316 Ends at: 324)
LOC:          |       9 |       |      OK |
metrics are OK
G_setenv (Begins at: 326 Ends at: 332)
LOC:          |       7 |       |      OK |
metrics are OK
G_setenv2 (Begins at: 334 Ends at: 340)
LOC:          |       7 |       |      OK |
metrics are OK
G__setenv (Begins at: 342 Ends at: 347)
LOC:          |       6 |       |      OK |
metrics are OK
G__setenv2 (Begins at: 349 Ends at: 354)
LOC:          |       6 |       |      OK |
metrics are OK
G_unsetenv (Begins at: 356 Ends at: 363)
LOC:          |       8 |       |      OK |
metrics are OK
G_unsetenv2 (Begins at: 365 Ends at: 372)
LOC:          |       8 |       |      OK |
metrics are OK
G__write_env (Begins at: 375 Ends at: 381)
LOC:          |       7 |       |      OK |
metrics are OK
G__env_name (Begins at: 383 Ends at: 393)
Complexity:   |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
G__read_env (Begins at: 395 Ends at: 400)
LOC:          |       6 |       |      OK |
metrics are OK
G__set_gisrc_file (Begins at: 402 Ends at: 409)
LOC:          |       8 |       |      OK |
metrics are OK
G__get_gisrc_file (Begins at: 411 Ends at: 414)
LOC:          |       4 |       |      OK |
metrics are OK
G__create_alt_env (Begins at: 416 Ends at: 431)
LOC:          |      16 |       |      OK |
metrics are OK
G__switch_env (Begins at: 433 Ends at: 448)
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  G_setenv2
In lib/gis/env.c clones of  G_setenv2 are:
	vector/v.digit/i_face.c  i_prompt_buttons
Threshold GRASS6 key metrics values at 2006-11-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
