[GRASS-QA] GRASS QA: markus | ./grass6/lib/proj/convert.c |no clones | 3 monsters | 1 warnings
Tue Nov 7 08:03:29 EST 2006
Hello markus,
ANALYSIS
lib/proj/convert.c functions
GPJ_grass_to_wkt (Begins at: 53 Ends at: 85)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
GPJ_grass_to_osr (Begins at: 87 Ends at: 256)
Complexity:   |      18 |     * |         |
CalledNBR:    |      63 |    ** | Warning |
LOC:          |     170 |     * |         |
at least 1 values are close to an outlier please consider revising code
GPJ_osr_to_grass (Begins at: 258 Ends at: 643)
Complexity:   |      39 |   *** | MONSTER |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      89 |   *** | MONSTER |
LOC:          |     386 |   *** | MONSTER |
3 metric are OUT OF RANGE!
GPJ_wkt_to_grass (Begins at: 645 Ends at: 666)
Complexity:   |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
GPJ_set_csv_loc (Begins at: 672 Ends at: 697)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
DatumNameMassage (Begins at: 729 Ends at: 776)
Complexity:   |       5 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
