[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.histogram/main.c |no clones | 0 monsters | 0 warnings
Tue Nov 7 23:40:36 EST 2006
Hello hamish,
ANALYSIS
display/d.histogram/main.c functions
main (Begins at: 44 Ends at: 203)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      60 |     * |         |
LOC:          |     160 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
