[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.vect/plot1.c |no clones | 4 monsters | 0 warnings
Sun Nov 12 02:52:02 EST 2006
Hello hamish,
ANALYSIS
display/d.vect/plot1.c functions
plot1 (Begins at: 14 Ends at: 428)
Complexity:   |      68 |   *** | MONSTER |
ParamNBR:     |      16 |   *** | MONSTER |
CalledNBR:    |     101 |   *** | MONSTER |
LOC:          |     415 |   *** | MONSTER |
4 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
