[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/getl.c |no clones | 0 monsters | 0 warnings
Sun Nov 12 02:52:02 EST 2006
Hello hamish,
ANALYSIS
lib/gis/getl.c functions
G_getl (Begins at: 17 Ends at: 50)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
G_getl2 (Begins at: 52 Ends at: 86)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-11-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
