[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/datetime.c |no clones | 2 monsters | 0 warnings
Wed Oct 11 05:10:37 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/datetime.c functions
db_convert_value_datetime_into_string (Begins at: 14 Ends at: 185)
Complexity:   |      49 |   *** | MONSTER |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      34 |       |      OK |
LOC:          |     172 |     * |         |
1 metric are OUT OF RANGE!
db_convert_Cstring_to_value_datetime (Begins at: 187 Ends at: 328)
Complexity:   |      45 |   *** | MONSTER |
CalledNBR:    |      33 |       |      OK |
LOC:          |     142 |     * |         |
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
