[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/dbmscap.c |no clones | 0 monsters | 0 warnings
Wed Oct 11 05:10:38 EDT 2006
Hello brad,
ANALYSIS
lib/db/dbmi_base/dbmscap.c functions
dbmscap_filename (Begins at: 22 Ends at: 40)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
db_dbmscap_filename (Begins at: 49 Ends at: 52)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
db_has_dbms (Begins at: 61 Ends at: 64)
LOC:          |       4 |       |      OK |
metrics are OK
db_copy_dbmscap_entry (Begins at: 73 Ends at: 92)
LOC:          |      20 |       |      OK |
metrics are OK
db_read_dbmscap (Begins at: 95 Ends at: 200)
CalledNBR:    |      16 |       |      OK |
LOC:          |     106 |       |      OK |
metrics are OK
add_entry (Begins at: 203 Ends at: 231)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
db_free_dbmscap (Begins at: 240 Ends at: 250)
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
