[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/raster.c |4 clones (
main.c main.c ask.c cats.c color_get.c color_rule.c env.c
key_value1.c quant.c raster.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:03 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/raster.c functions
G_incr_void_ptr (Begins at: 32 Ends at: 54)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 23 | | OK |
metrics are OK
G_raster_cmp (Begins at: 56 Ends at: 100)
Complexity: | 14 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 45 | | OK |
metrics are OK
G_raster_cpy (Begins at: 102 Ends at: 123)
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_set_raster_value_c (Begins at: 125 Ends at: 159)
Complexity: | 6 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_set_raster_value_f (Begins at: 161 Ends at: 195)
LOC: | 35 | | OK |
metrics are OK
G_set_raster_value_d (Begins at: 197 Ends at: 235)
LOC: | 39 | | OK |
metrics are OK
G_get_raster_value_c (Begins at: 237 Ends at: 270)
LOC: | 34 | | OK |
metrics are OK
G_get_raster_value_f (Begins at: 272 Ends at: 305)
LOC: | 34 | | OK |
metrics are OK
G_get_raster_value_d (Begins at: 307 Ends at: 325)
LOC: | 19 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
G_get_raster_value_f G_get_raster_value_c G_set_raster_value_f G_set_raster_value_c
In lib/gis/raster.c clones of G_set_raster_value_f are:
lib/gis/raster.c G_set_raster_value_c
In lib/gis/raster.c clones of G_get_raster_value_c are:
lib/gis/raster.c G_get_raster_value_f
In lib/gis/raster.c clones of G_set_raster_value_c are:
lib/gis/raster.c G_set_raster_value_f
In lib/gis/raster.c clones of G_get_raster_value_f are:
lib/gis/raster.c G_get_raster_value_c
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
