[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/window_map.c |no clones | 0 monsters | 0 warnings
Fri Apr 13 20:44:04 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/window_map.c functions
G__create_window_mapping (Begins at: 35 Ends at: 129)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      95 |       |      OK |
metrics are OK
G_northing_to_row (Begins at: 131 Ends at: 152)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_adjust_east_longitude (Begins at: 154 Ends at: 180)
Complexity:   |       3 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
G_adjust_easting (Begins at: 182 Ends at: 208)
CalledNBR:    |       1 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
G_easting_to_col (Begins at: 210 Ends at: 236)
LOC:          |      27 |       |      OK |
metrics are OK
G_row_to_northing (Begins at: 238 Ends at: 259)
LOC:          |      22 |       |      OK |
metrics are OK
G_col_to_easting (Begins at: 261 Ends at: 292)
LOC:          |      32 |       |      OK |
metrics are OK
G_window_rows (Begins at: 294 Ends at: 327)
LOC:          |      34 |       |      OK |
metrics are OK
G_window_cols (Begins at: 329 Ends at: 343)
LOC:          |      15 |       |      OK |
metrics are OK
G__init_window (Begins at: 345 Ends at: 370)
Complexity:   |       2 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
G_row_repeat_nomask (Begins at: 372 Ends at: 403)
Complexity:   |       5 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
