[GRASS-QA] GRASS QA: glynn | ./grass6/lib/g3d/g3derror.c |1 clones ( input.c georef.c ask.c fpcompress.c g3derror.c )| 0 monsters | 0 warnings
Sun Apr 15 17:07:52 EDT 2007
Hello glynn,
ANALYSIS
lib/g3d/g3derror.c functions
G3d_skipError (Begins at: 26 Ends at: 40)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G3d_printError (Begins at: 43 Ends at: 60)
CalledNBR:    |       3 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
G3d_fatalError (Begins at: 63 Ends at: 74)
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
G3d_fatalError_noargs (Begins at: 77 Ends at: 81)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
G3d_error (Begins at: 84 Ends at: 88)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  G3d_fatalError
In lib/g3d/g3derror.c clones of  G3d_fatalError are:
	gem/error.c  print_warning
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
