[GRASS-QA] GRASS QA: glynn | ./grass6/lib/vector/diglib/cindex.c |no clones | 0 monsters | 0 warnings
Sun Apr 15 17:07:52 EDT 2007
Hello glynn,
ANALYSIS
lib/vector/diglib/cindex.c functions
dig_cidx_init (Begins at: 29 Ends at: 39)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
dig_cidx_free (Begins at: 43 Ends at: 64)
Complexity:   |       1 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
dig_cidx_add_cat (Begins at: 67 Ends at: 124)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
cmp_cat (Begins at: 127 Ends at: 135)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
cmp_field (Begins at: 138 Ends at: 153)
LOC:          |      16 |       |      OK |
metrics are OK
dig_cidx_add_cat_sorted (Begins at: 156 Ends at: 241)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
dig_cidx_del_cat (Begins at: 244 Ends at: 295)
Complexity:   |       6 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
dig_cidx_sort (Begins at: 303 Ends at: 328)
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
