[GRASS-QA] GRASS QA: jachym | ./grass6/display/d.mon/pgms/stop.c |no clones | 0 monsters | 0 warnings
Sun Jan 28 07:09:10 EST 2007
Hello jachym,
ANALYSIS
display/d.mon/pgms/stop.c functions
main (Begins at: 15 Ends at: 46)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
usage (Begins at: 48 Ends at: 52)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
stop_mon (Begins at: 55 Ends at: 92)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
