[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.sample/main.c |no clones | 1 monsters | 0 warnings
Sun Jan 28 16:32:34 EST 2007
Hello markus,
ANALYSIS
vector/v.sample/main.c functions
main (Begins at: 51 Ends at: 303)
Complexity:   |      24 |     * |         |
CalledNBR:    |     109 |   *** | MONSTER |
LOC:          |     253 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
