[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/color_rules.c |no clones | 2 monsters | 0 warnings
Tue Jul 24 03:33:01 EDT 2007
Hello markus,
ANALYSIS
lib/gis/color_rules.c functions
G_parse_color_rule (Begins at: 43 Ends at: 108)
Complexity:   |      10 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      10 |       |      OK |
LOC:          |      66 |       |      OK |
1 metric are OUT OF RANGE!
G_parse_color_rule_error (Begins at: 110 Ends at: 122)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
G_read_color_rule (Begins at: 124 Ends at: 155)
Complexity:   |       5 |       |      OK |
LOC:          |      32 |       |      OK |
G_read_color_rules (Begins at: 157 Ends at: 226)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       7 |       |      OK |
LOC:          |      70 |       |      OK |
metrics are OK
load_rules_file (Begins at: 228 Ends at: 243)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_load_colors (Begins at: 245 Ends at: 248)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
G_load_fp_colors (Begins at: 250 Ends at: 253)
LOC:          |       4 |       |      OK |
metrics are OK
load_rules_name (Begins at: 255 Ends at: 262)
LOC:          |       8 |       |      OK |
metrics are OK
G_make_colors (Begins at: 264 Ends at: 267)
LOC:          |       4 |       |      OK |
metrics are OK
G_make_fp_colors (Begins at: 269 Ends at: 272)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
