[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/find_vect.c |no clones | 0 monsters | 0 warnings
Tue Jul 24 04:47:38 EDT 2007
Hello martinl,
ANALYSIS
lib/gis/find_vect.c functions
G_find_vector (Begins at: 56 Ends at: 75)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
G_find_vector2 (Begins at: 78 Ends at: 82)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
