[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gpde/N_gradient_calc.c |no clones | 0 monsters | 0 warnings
Thu Jun 7 07:25:30 EDT 2007
Hello glynn,
ANALYSIS
lib/gpde/N_gradient_calc.c functions
N_calc_gradient_field_2d_stats (Begins at: 29 Ends at: 102)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
N_compute_gradient_field_2d (Begins at: 104 Ends at: 239)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      27 |       |      OK |
LOC:          |     136 |     * |         |
metrics are OK
N_compute_gradient_field_components_2d (Begins at: 242 Ends at: 287)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
N_calc_gradient_field_3d_stats (Begins at: 289 Ends at: 372)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      84 |       |      OK |
metrics are OK
N_compute_gradient_field_3d (Begins at: 374 Ends at: 564)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |     191 |     * |         |
metrics are OK
N_compute_gradient_field_components_3d (Begins at: 567 Ends at: 616)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-07 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
