[GRASS-QA] GRASS QA: glynn | ./grass6/general/g.gisenv/main.c |no clones | 0 monsters | 0 warnings
Fri Jun 8 20:17:57 EDT 2007
Hello glynn,
ANALYSIS
general/g.gisenv/main.c functions
main (Begins at: 24 Ends at: 115)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      92 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
