[GRASS-QA] GRASS QA: markus | ./grass6/db/base/describe.c |no clones | 0 monsters | 0 warnings
Wed Jun 27 12:44:05 EDT 2007
Hello markus,
ANALYSIS
db/base/describe.c functions
main (Begins at: 31 Ends at: 86)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
parse_command_line (Begins at: 89 Ends at: 143)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-27 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
