[GRASS-QA] GRASS QA: markus | ./grass6/db/base/printtab.c |no clones | 0 monsters | 0 warnings
Wed Jun 27 12:44:05 EDT 2007
Hello markus,
ANALYSIS
db/base/printtab.c functions
print_table_definition (Begins at: 7 Ends at: 36)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
print_column_definition (Begins at: 39 Ends at: 63)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
print_priv (Begins at: 66 Ends at: 79)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-27 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
