[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/header.c |no clones | 4 monsters | 0 warnings
Thu Mar 1 19:38:40 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/header.c functions
G3d_readWriteHeader (Begins at: 36 Ends at: 100)
Complexity:   |       3 |       |      OK |
ParamNBR:     |      28 |   *** | MONSTER |
CalledNBR:    |      27 |       |      OK |
LOC:          |      65 |       |      OK |
1 metric are OUT OF RANGE!
G3d_readHeader (Begins at: 105 Ends at: 142)
Complexity:   |       4 |       |      OK |
ParamNBR:     |      27 |   *** | MONSTER |
CalledNBR:    |      11 |       |      OK |
LOC:          |      38 |       |      OK |
G3d_writeHeader (Begins at: 147 Ends at: 210)
CalledNBR:    |      10 |       |      OK |
LOC:          |      64 |       |      OK |
G3d_cacheSizeEncode (Begins at: 213 Ends at: 223)
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
G3d__computeCacheSize (Begins at: 228 Ends at: 251)
Complexity:   |      10 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G3d_fillHeader (Begins at: 260 Ends at: 399)
Complexity:   |      19 |     * |         |
ParamNBR:     |      30 |   *** | MONSTER |
CalledNBR:    |      26 |       |      OK |
LOC:          |     140 |     * |         |
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
