[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.class/outline.c |no clones | 0 monsters | 0 warnings
Tue Mar 6 16:58:13 EST 2007
Hello brad,
ANALYSIS
imagery/i.class/outline.c functions
outline (Begins at: 22 Ends at: 163)
Complexity:   |      18 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |     142 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
