[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.class/redisplay.c |no clones | 0 monsters | 0 warnings
Tue Mar 6 16:58:13 EST 2007
Hello brad,
ANALYSIS
imagery/i.class/redisplay.c functions
redisplay (Begins at: 10 Ends at: 26)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
redisplay_both (Begins at: 29 Ends at: 35)
LOC:          |       7 |       |      OK |
metrics are OK
redisplay_map (Begins at: 38 Ends at: 47)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
redisplay_zoom (Begins at: 50 Ends at: 64)
CalledNBR:    |       5 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
cancel_redisplay (Begins at: 67 Ends at: 70)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
