[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/parse_ftcap.c |no clones | 0 monsters | 0 warnings
Wed May 2 04:44:27 EDT 2007
Hello glynn,
ANALYSIS
lib/driver/parse_ftcap.c functions
parse_freetypecap (Begins at: 9 Ends at: 66)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
free_freetypecap (Begins at: 68 Ends at: 84)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
