[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/font_freetype.c |no clones | 0 monsters | 0 warnings
Wed May 2 04:44:27 EDT 2007
Hello glynn,
ANALYSIS
lib/driver/font_freetype.c functions
font_init_freetype (Begins at: 10 Ends at: 26)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
font_init_charset (Begins at: 28 Ends at: 34)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
font_get_freetype_name (Begins at: 36 Ends at: 39)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
font_get_charset (Begins at: 41 Ends at: 46)
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
font_get_index (Begins at: 48 Ends at: 51)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
