[GRASS-QA] GRASS QA: markus | ./grass6/db/base/select.c |no clones | 0 monsters | 0 warnings
Wed May 30 04:34:26 EDT 2007
Hello markus,
ANALYSIS
db/base/select.c functions
main (Begins at: 34 Ends at: 89)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
sel (Begins at: 92 Ends at: 165)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
parse_command_line (Begins at: 168 Ends at: 278)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      35 |       |      OK |
LOC:          |     111 |       |      OK |
metrics are OK
get_stmt (Begins at: 281 Ends at: 302)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
stmt_is_empty (Begins at: 305 Ends at: 310)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
print_column_definition (Begins at: 313 Ends at: 322)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
