[GRASS-QA] GRASS QA: markus | ./grass6/db/base/execute.c |no clones | 0 monsters | 0 warnings
Wed May 30 04:34:26 EDT 2007
Hello markus,
ANALYSIS
db/base/execute.c functions
main (Begins at: 32 Ends at: 86)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
parse_command_line (Begins at: 88 Ends at: 139)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
get_stmt (Begins at: 142 Ends at: 168)
CalledNBR:    |       8 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
stmt_is_empty (Begins at: 171 Ends at: 176)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
