[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.null/null.c |1 clones ( null.c )| 0 monsters | 0 warnings
Mon Nov 12 10:36:20 EST 2007
Hello carlos,
ANALYSIS
raster/r.null/null.c functions
main (Begins at: 15 Ends at: 183)
Complexity:   |      16 |     * |         |
CalledNBR:    |      60 |     * |         |
LOC:          |     169 |     * |         |
metrics are OK
parse_vallist (Begins at: 185 Ends at: 218)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
parse_d_mask_rule (Begins at: 221 Ends at: 250)
ParamNBR:     |       3 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
process (Begins at: 253 Ends at: 295)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
doit (Begins at: 298 Ends at: 346)
CalledNBR:    |      18 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  parse_vallist
In raster/r.null/null.c clones of  parse_vallist are:
	display/d.rast/main.c  parse_vallist
	display/d.rast/main.c  parse_catlist
Threshold GRASS6 key metrics values at 2007-11-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
