[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.surf.idw2/read_cell.c |no clones | 0 monsters | 0 warnings
Mon Nov 12 10:36:22 EST 2007
Hello carlos,
ANALYSIS
raster/r.surf.idw2/read_cell.c functions
read_cell (Begins at: 8 Ends at: 63)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
