[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/sqlite/fetch.c |no clones | 0 monsters | 0 warnings
Sat Nov 24 07:58:55 EST 2007
Hello markus,
ANALYSIS
db/drivers/sqlite/fetch.c functions
db__driver_fetch (Begins at: 37 Ends at: 193)
Complexity:   |      19 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      37 |     * |         |
LOC:          |     157 |     * |         |
metrics are OK
db__driver_get_num_rows (Begins at: 196 Ends at: 242)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
